HammerSludge
Feb 04, 2022Aspirant
XR1000 - OPEN NAT NOT WORKING
Hi, Need serious help on changing NAT type to OPEN. My network provider gave me router, in that i enabled UPnp, and added a entry for port forwarding. and as last step changing my IP to static....
- Feb 04, 2022
I can't see the images you've attached as they're not yet moderated I'm afraid.
What's the exact make and model of your ISP router/modem?
What I would suggest doing would be to remove your port forwarding rules, then put the XRs WAN IP in the ISP router/modem's DMZ. Then, make sure that IP is reserved for the XR in the ISP router/modem's LAN settings, this will ensure it doesn't change again in future.
After that, your NAT should be open.
Netduma-Liam
Feb 04, 2022NetDuma Partner
HammerSludge
Thank you so much. It worked!!
Another query. Whenever i restart my XR1000, the duma os is not working. it says "Duma OS not loaded". I will have to factory reset the router, and do all those initial setup again, then only the duma OS loads. Currenly Im in this verson "1.0.0.58_1.0.44". This happen everytime. Any fix for that?
- Netduma-LiamFeb 04, 2022NetDuma Partner
Awesome, no problem!
How long approximately are you waiting after the reboot before accessing the interface? I'd suggest leaving it a good few minutes otherwise you would definitely expect to see the 'DumaOS has not loaded yet' splash page.
- HammerSludgeFeb 04, 2022AspirantI left it for around around 15 to 20 minutes. Should I wait for another 20min?
No that should be plenty enough, perhaps try clearing cach and refreshing the browser. The browser may have cached that splash page for some reason.
