HammerSludge
Feb 04, 2022Aspirant
XR1000 - OPEN NAT NOT WORKING
Hi, Need serious help on changing NAT type to OPEN. My network provider gave me router, in that i enabled UPnp, and added a entry for port forwarding. and as last step changing my IP to static....
- Feb 04, 2022
I can't see the images you've attached as they're not yet moderated I'm afraid.
What's the exact make and model of your ISP router/modem?
What I would suggest doing would be to remove your port forwarding rules, then put the XRs WAN IP in the ISP router/modem's DMZ. Then, make sure that IP is reserved for the XR in the ISP router/modem's LAN settings, this will ensure it doesn't change again in future.
After that, your NAT should be open.
Netduma-Liam
Feb 04, 2022NetDuma Partner
No that should be plenty enough, perhaps try clearing cach and refreshing the browser. The browser may have cached that splash page for some reason.
HammerSludge
Feb 05, 2022Aspirant
Im sorry. No it does not work. Cleared cookies and cache. tried different browser. Waited for long time. Still "Duma OS not loaded".
- HammerSludgeFeb 05, 2022Aspirant
It comes like this. Pls help
DumaOS not loaded yet!
Don't worry we will redirect you shortly.
TR-1 TH-1 DR-0
- Netduma-FraserFeb 06, 2022NetDuma PartnerWhen you restart the router how do you do that - using button on the back, pulling the power or via the interface?
Do you have Armor enabled?- HammerSludgeFeb 06, 2022Aspirant
I tried with the mobile app to restart the modem, also i used the button in the router. Both were giving me same problem.
No. Armor is not activated
