pbudreski
May 19, 2024Tutor
XR1000 & Blink Security Cameras
Hello - I am looking for advice on the XR 1000 router in connection with Blink Security Cameras. Under Device Manager - Network Map, I have discovered the 4 cameras and corrected the type of equipmen...
- Jul 01, 2024
Hello everyone
Happy to advise this forum & those who opined on the issue we were encountering with the Blink cameras. After 2 hours on phone with NetGear tech support & 2 hours on phone with Blink tech support, the problem was the Blink Sync Monitor. Defective & once replaced, issue was resolved.
Many thanks - Happy Canada Day to the canucks July 1 & Fourth of July to USA residents.
SouthernGypsy
May 19, 2024Apprentice
I've been using Blink cameras since they first came out, Hopefully I can both answer you and give you some general advice/ideas if your new to them...
First off, the short answer to your question is that is all you have to do to have them work, though I have found you get more reliable connectivity (like the time it takes for the Sync Modules to re-connect after an internet outage) if you assign your blink modules fixed IP addresses. Oh, and in the pull-down menu I set both cameras AND the sync modules themselves as "Security Cameras".
Now, for some more info on a blink setup... In our example we're on a Horse ranch with a couple of hundred total acres, though most is wooded or fields and creeks running through it. The road we live on is in fact named after our ranch and even though it's technically a county road it's really our private driveway that runs in fromt the side to our place which sits along a large creek and we own eveything for about 3/4 mile down stream and 2 miles upstream and 1 mile in the other directions. The road dead ends at our stables after passing by our two houses, a large work shop, a large equipment shed for the tractors, etc. some other smaller storage buildings, and then ends in a circle drive in front of the main stables. We have two Nighthawk Routers; the XR1000v2 is the main in the main house, an RAX54v2 set in Wireless Access Point mode in the second house, and two older Wireless Access Points, one in our Stables and one in a our large shop. All of them are hardwired back to the main router.
We often do open to the public trail rides on both horseback and on ATV, SxS, UTV and Jeeps with almost 20 miles of trails on our land up in the woods. So a lot of people know about our place and the woods. And once or twice over the years we have a couple of unscrupulous people try to use our own trails through the woods to try and sneak up from the backside on an ATV or UTVs when we was known to be away. Our shop alone contains about every kind of tool you can think of and tools make easy targets for meth heads to steal and try to pawn.
So to combat this we have three Blink Sync Modules and a total of 27 Cameras; 10 outside connected to what I named "Sync Module 1", and 5 inside the house and 1 each inside the stable and the main work shed connected to what I named "Sync Module 2", and 10 around the outside of our stables and large shop area and equipment sheds connected to what I named "Sync Module 3" in the router settings when I gave the sync modules fixed IP Addresses in the router "LAN Setup" page via their MAC address. In my phones Blink App the the three Sync Modules are simply named "Outdoor", "Indoor", and "Shop/Stables". I leave the Outdoor ones on all the time, have the Shop/Stables set with the timer in the app to come on of the evening and turn off in the morning, but only turn the Indoor ones on when we're going to be away from the house for extended periods. And honestly you can't get close to anywhere on the property without tripping at least a couple of the Outdoor ones anyway.
They are setup in a ring around the ranch with each ones view overlapping the view of the next one, of not two others.... IE. someone can't try to sneak up from the side out of the view of a camera and spray the lens with black paint or hit it with a bat or something because you can't get close to any of them without being seen by several of them long before you get close enough. That was a mistake a neighbor made, he thought just one on his gate at the road would be enough thinking anyone would have to come through the gate to get in. But someone just stayed close to the fence until they was near the camera on his gate and then sprayed the lenses with black paint, signaled their buddy who was waiting down the road with a UTV, came into his property, broke in his garage, and stole a UTV bed full of tools and gear. Anyway, I also have a couple of extras aimed at things like the mailbox and one inside a smaller work shed up aimed down at the only door. So if your new to cameras keep that in mind, if you set one up where there is a way for someone to skulk against a wall or fence and get up beside it without being seen, crooks like to carry a can of black paint and will try that and then spray the lens from the side.
The little Cameras themselves it's harder to assign a fixed IP too because while they are connected to the WIFI they seem controled more through the Sync modules most of the time rather than the WIFI. The WIFI does see them. The Sync Modules themselves act as little mini-controllers for the cameras assigned to them and control the cameras, even though the cameras are also connected direct to the WIFI. All the cameras do show up in the "Device Manager" tab looking at the Network Map but yet show as Offline most of the time even though they are all working. The only time a camera itself will show as Online is when your actually using your phone and watching it "Live". They all have obscure names so if you want to give them names in Device manager that is the only way to do it, sit at your computer with the DumaOS loaded on the Device Manager/Network Map page and load your Blink App, go one by one hitting the > (Play) button and watch which one momentarily moves from Offline to Online. Then you can give it a Unique name and if your fast enough maybe assign a static IP though I never bothered with the static IP part on ours.
This seems to be normal behavior for them. As far as setup, as I said I just assigned Fixed IP addresses to each Sync Module and then set all the Sync Modules and all the Cameras as "Security Camera" on that page and hit Apply. If your new to Blink cameras and using batteries (as opposed to running a wire) keep in mind when they say to only use Lithium Ion batteries (we've found the best to be Energizer Ultimate Lithium) they are serious. A friend has some and had a couple of cameras in need of a new battery's one time, didn't have lithium, so just stuck in regular AA batteries, they worked for a couple more weeks then both cameras went DOA and have never worked again since and he had to replace them, all his other cameras he put lithium in was still fine. Some of ours are still first Gen Blink cameras and still work great.
- pbudreskiMay 20, 2024Tutor
Thanks for this - I now have all the devices named by location and located the Sync Manager. My devices table has many entries. To be truthful, there are two Iphones, two Ipads, 4 Fire Sticks, an ADT alarm system with one camera, 3 Smart Home Devices for lights. There was an option to remove offline devices. If deployed, will another device (say laptop) using WIFI that has been off for a week be added to list. Again many thanks.
- SouthernGypsyMay 20, 2024Apprentice
If the devices that are offline are your devices then don't delete them. I have fixed IP addresses assigned to things like a laptop which I really only use when traveling, a Fire TV Stick 4K that I also only use when traveling, and a GPS that stays in my Jeep, oh and the Alpine stereo in the Jeep itself. I have them assigned fixed IP addresses so I know what they are and can name them for those times when I do bring them inside for an update prior to a trip, occasionally checking for an update for the GPS, and even updating the firmware/software in the Jeeps stereo sitting in the garage. Everything here has a fixed IP address and a name, even friends and relatives phones who visit often. So the only things that ever show up as "unknown device" is when I have some random person visit who doesn't visit often enough to merit assigning a fixed IP address for their phone, those I will occasionally delete. If I go to the Device Manager tab some evening and see something that says unknown device, and I don't have any visitors and no one has visited since I last deleted the unknown ones, then I know something unauthorized might be connecting.
Again, thanks. How do I affix an IP address to the cameras & Link Module
