Proxxee
Nov 04, 2023Guide
XR1000 + CM1000 Increased Ping in COD
I recently upgraded from a xr450 to a xr1000 to better handle my connection. My connection benchmark is giving me all A+ with a sub 30ms ping which is great. However, my in-game ping has actually dou...
Netduma-Fraser
Nov 04, 2023NetDuma Partner
Where abouts are you located? Could you attach a picture of your Geo-Filter page please? What is the model of the modem/router the 1000 is connected to and if necessary have you entered the 1000 in the modem DMZ?
- ProxxeeNov 04, 2023Guide
I'm in East-Central Alabama. Modem is a CM1000v1. Router is a XR1000/AX5400. I havent put anything in the DMZ
Also, autoping isnt working at all.
- Netduma-FraserNov 04, 2023NetDuma PartnerTry this:
Quit the application/game/client completely
Remove device from the Geo-Filter
Resync from the Geo-Filter Map menu
Re-add the device to the Geo-Filter with the manual option
Set up the Geo-Filter how you like
Wait 2 minutes
Boot up application/game/client
Then see if it works better- ProxxeeNov 04, 2023Guide
I'll give that a go later. Wife n kids...Know how that goes.
Edit: Derp. I read reboot router. I've done the above multiple times to no avail.
- FURRYe38Nov 07, 2023Guru - Experienced User
Please post a copy and paste of the modems connection status data and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
- ProxxeeNov 07, 2023Guide
CM1000 https://gyazo.com/81c1dbecff156fee6801c28962bf3ff4
CM1000 p2 https://gyazo.com/72238cb1ba80617ad856162e57f2d510
