Proxxee
Nov 04, 2023Guide
XR1000 + CM1000 Increased Ping in COD
I recently upgraded from a xr450 to a xr1000 to better handle my connection. My connection benchmark is giving me all A+ with a sub 30ms ping which is great. However, my in-game ping has actually dou...
Nov 07, 2023Guru - Experienced User
Yes and reference the info I posted about the logs.
Proxxee
Nov 07, 2023Guide
Will do. I'll get that scheduled now. Thanks.
- ProxxeeNov 07, 2023Guide
Deep Sigh... https://gyazo.com/5af872cbf57177a0c680e028c660d143
- FURRYe38Nov 07, 2023Guru - Experienced User
Get on site tech. Logs show otherwise.
Friday at 9am
I'll report back with the results on Friday afternoon or evening once I've reset my network. Thanks for your help thus far.
- ProxxeeNov 10, 2023GuideHad an experienced and pretty knowledgeable tech for a change. He said that the physical lines were in great shape w/ no splitters. There were some correctables that he managed to clean up but he said that the criticals came from a node issue that didn’t immediately trigger their warning signal to auto-dispatch a tech on their end. He says the issue has now been identified and turnaround is typically a few days but may require a few weeks depending on scheduling. Thanks! I was ready to send this thing back because the XR450 was working completely fine. I only upgraded because I wanted to increase my speeds and needed a router that could handle it. The logical move was the XR1000. It gave me issues straight out of the box, mostly with the geofilter that’s still not working, but my actual in-game latency hasn’t been high in MW3 so we seem to be on an upward trajectory.
- FURRYe38Nov 11, 2023Guru - Experienced User
Sounds like a better direction on the ISP side.
What speeds do you pay for UP and down?
My XR450 and XR1000 both handle my 1G/50Mbps just fine here.
