ryanstras
Dec 02, 2020Aspirant
XR1000 | Extender or Mesh
I recently purchased a Nighthawk XR1000 router and have been considering an addition to my setup to resolve a weak Wi-Fi signal on the opposite side of my house; specifically in my wife's office spac...
ryanstras
1. My home is roughly 1300 sqare feet.
2. The majority of my walls are just drywall but the room that my setup is in (including the router) is an addition built onto the house, this actually puts a brick wall between the router and the remainder of the house. If I were to get the Orbi system I would place one next to the router and the other in my wifes office which are on opposite sides of the house, I'm not sure of the exact distance right now but I would estimate ~50 feet between them.
3. I was considering the Tri-Band AX6000 for the backhaul feature. Widespread speed, connection reliability, future proofing, and my wife's peace of mind is mainly what I'm looking for here. Peak speeds specifically around the XR1000 is not a main concern because I have my equipment in that room hardwired.
My main cause for concern and advice is that I have had bad experience with extenders in the past providing low performance or connection drops as well as some issues handing off the connection from router to extender. My most recent experience was with a Powerline adapter that included Wi-Fi extension and that did not work well in my situation (this may be due to the poor connection I'm getting from the outlet, I'm not sure). With that said the EAX80 is a fancier and more costly device so the experience may be different.
The Orbi setup in conjunction with the XR1000 seems like it may be overkill but I feel like it would be a pretty clean setup allowing the XR1000 to handle my PC/Gaming/Media needs using a hardwired connection giving me the benefits of DumaOS while allowing the Orbi setup to blanket the house in a solid Wi-Fi connection. Although these devices are expensive and my networking knowledge is rather limited which is why I seek advice before making a commitment. I want to create a home network that will not require updrades for the time I will live in this house; ~10 years planned.
Dec 02, 2020Guru - Experienced User
that brick wall is going to cause issues with everything. its one of the best blockers of wifi.
And 1300sq ft isn't a large home. The XR1000 should cover it without issues if it wasn't for the brick. The orbi might not work right as they need to be at least 30ft apart or you can have issues.
You're correct in extenders causing issues. Single and dual band extenders cause a 50% reduction in speed because they have to go router----extender and then extender----device. An they can't do both at once. Plus they increase latency. The tri-bands are much better because they have a dedicated 5ghz just for router---extender. I haven't used an EAX unit yet so I can't compare it with my EX8000 to give you an idea of performance differences. With the AX spec allowing higher initial bandwidth, I've been curious to see what the performance difference is between the two but the wife hasn't given the OK to buy and and try. Sorry.
Thoughts on it? Any chance you could drill though the office wall with brick and hardwire in your wife's pc/laptop? You could put an extender/orbi on one side, pass a cable through, and have a switch (or not if not needed) to connect her devices to. If its a dedicated office, this might be a better option.
Sorry, its going to be tough because of that brick. Wifi isn't going to pass through it well at all. If you can get an ethernet wire or coax wire through there, you'll be much better off. If you've already got a coax run to the office, you could use moca adapters.
- ryanstrasDec 02, 2020AspirantI was trying to avoid running a cable throughout the house but I will give it some more thought when I get home and can look everything over again. I do not believe there is a coax run to her office so moca adapters may be out of the question.
I believe the Orbi’s would have a larger distance than 30 feet between them but I’ll measure that out too when I get home. Either way it sounds like the brick wall may cause some issues.
Seems running a cable through the house is the best option but I really wasn’t looking forward to making that happen, haha- plemansDec 02, 2020Guru - Experienced User
You don't have to run the cable throughout the house. Both orbi and the EAX80 have an ethenet port. Just put it right at the office wall, drill through the wall at floor board or wherever you'd prefer a connection and go through there.
so:
XR1000-----wireless--->Extender--lan--|wall|---lan---->office setup
