Belvedere89
Jun 24, 2021Aspirant
XR1000 + Xbox series X High ping
Hi everyone Here is my situation : I am in canada, with Telus on 1gbps fiber connection. I had a telus router that didnt have QoS and my ping were always high. So i decided to change every cable ...
Netduma-Fraser
Jun 25, 2021NetDuma Partner
What is your average ping from speedtest.net when nothing is using the internet? What servers are you trying to force with the Geo-Filter?
What is the layout of your setup exactly, could you break it down for me so I have an idea of where the XR fits in?
E.g. modem > velop > Wireless devices
> XR
> XR
Belvedere89
Jun 25, 2021Aspirant
my ping is 1ms in average from telus mobility server.
my routing goes as follow : modem ( fiber ) > xr1000 > pc, xbox series x and velop(bridge mode)
then the velop goes : velop > wall plug, outdoor/underground cat6 into tube going back inside in the living room to velop > 5 port switch > dvr for security camera and samsung tv. ( i did all the test with the velop disconnected from the xr1000 and turn off the velop itself from power to delete any interference from the wifi ). Same results.
Xr1000 has about 30 devices connected to it, but not always on at once.
- Netduma-FraserJun 25, 2021NetDuma PartnerWhat servers are you trying to force with the Geo-Filter?
- Belvedere89Jun 25, 2021Aspirant
sorry forgot to answer that. i set up the geofilter from the westcoast to the border of texas with a diagonal going to chicago area and back with the polygon tool. Los angeles, Oregon, Texas servers are decents for me since im in Edmonton, Alberta. Even more servers would be suitable since my friend is having decent ping on many others but my set up is always 30-40 ping higher than his when we are on the same warzone server.
- Netduma-FraserJun 25, 2021NetDuma PartnerWhats the average ping shown on the Geo-Filter compared with what is shown on the game? Could you reset Bandwidth Allocation completely please and see if that has an affect?
