Belvedere89
Jun 24, 2021Aspirant
XR1000 + Xbox series X High ping
Hi everyone Here is my situation : I am in canada, with Telus on 1gbps fiber connection. I had a telus router that didnt have QoS and my ping were always high. So i decided to change every cable ...
Netduma-Fraser
Jul 04, 2021NetDuma Partner
What is the exact model of your modem? Also connect directly to the modem without anything else connected, what ping do you get then? Also while direct to the modem do a speedtest.net test, what ping does it show?
Belvedere89
Jul 06, 2021Aspirant
modem : huawei echolife HG8240u
Xbox on modem :
xbox setting stats for speed : 1080mbps down 643 up with 46 ms with 0 packet loss and 1480 mtu
xbox microsoft edge speedtest.net : 950mbps down 940 up 3 ms
xbox thru xr1000 settings stats : 1170 mbps down 599 up 41 ms
xbox speed test on edge :
1st try : 2 ms 600 mbps down 945 up
2nd try : 1 ms 560 mbps down 945 up
3rd try : 3 ms 950mbps down 935 up ( this one was done with real speed test app on xbox series x which uses speedtest.net )
4th try using same app : 3ms 940 down 940 up
While connected straight to modem to my xbox series x in solo warzone : 1. 100ms 2. 105ms 3. 90ms 4. 110ms
