Belvedere89
Jun 24, 2021Aspirant
XR1000 + Xbox series X High ping
Hi everyone Here is my situation : I am in canada, with Telus on 1gbps fiber connection. I had a telus router that didnt have QoS and my ping were always high. So i decided to change every cable ...
Belvedere89
Jul 06, 2021Aspirant
modem : huawei echolife HG8240u
Xbox on modem :
xbox setting stats for speed : 1080mbps down 643 up with 46 ms with 0 packet loss and 1480 mtu
xbox microsoft edge speedtest.net : 950mbps down 940 up 3 ms
xbox thru xr1000 settings stats : 1170 mbps down 599 up 41 ms
xbox speed test on edge :
1st try : 2 ms 600 mbps down 945 up
2nd try : 1 ms 560 mbps down 945 up
3rd try : 3 ms 950mbps down 935 up ( this one was done with real speed test app on xbox series x which uses speedtest.net )
4th try using same app : 3ms 940 down 940 up
While connected straight to modem to my xbox series x in solo warzone : 1. 100ms 2. 105ms 3. 90ms 4. 110ms
Belvedere89
also with my computer connected to xr1000 : 4 tests at 650 down and 650 up with 1 ms. ( average. some test at 645, some at 660 )
closed the window, and did another one : 3 tests at 860 down 940 up 1 ms.
- Netduma-FraserJul 06, 2021NetDuma PartnerThank you for all that information, as your pings are good except for to the game even direct to the modem I think it must be the routing to the server and that's not something we can resolve directly - that's down to the ISP
