polscifreak
Dec 15, 2022Guide
XR1000 2.4 Stops working
I bought an XR1000 a couple of years ago and haven't had any issues until recently. For about the last two months, the 2.4 band will stop working and nothing can connect to it. Rebooting the router...
Netduma-Fraser
Dec 16, 2022NetDuma Partner
How often does it occur? Are you using Smart Connect? Do 5GHz and wired devices continue to work?
- polscifreakDec 16, 2022Guide
At this point, it occurs about every day and a half. All my devices on the 2.4 GHz channel go offline.
5 GHz and wired devices work just fine.
Rebooting the router restores connectivity.
I am not using smart connect.
