polscifreak
Dec 15, 2022Guide
XR1000 2.4 Stops working
I bought an XR1000 a couple of years ago and haven't had any issues until recently. For about the last two months, the 2.4 band will stop working and nothing can connect to it. Rebooting the router...
Dec 16, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How is the wifi settings configured?
What do you have connected to the 2.4Ghz radio?
For about the last two months, the 2.4 band will stop working and nothing can connect to it. Rebooting the router fixes it.
I've tried several firmware versions and have the same result.
Any ideas?
- michaelkenwardDec 16, 2022Guru - Experienced User
FURRYe38 wrote:
Is there an echo in here?
- polscifreakDec 16, 2022Guide
For my modem, I'm using a Netgear CM1000v2.
WIFI Settings:
2.4 GHz
Enable AX
Enable SSID Broadcast
Enable 20/40 MHz Coexistence
Auto Channel
Mode: up to 600 Mbps
Transmit Power: 100%
WPA-Personal [TKIP] + WPA2-Personal [AES]
5 GHz
Channel:36
Mode: up to 4800 mbps
I don't seem to be having any issues with the 5 GHz band.
On the 2.4, I mainly have my smart home devices connected. Everything else I try to get on the 5. When the issue occurs, even my phone will not connect to the 2.4, but can connect to the 5.
In range, I only see two other wifi networks.
- FURRYe38Dec 16, 2022Guru - Experienced User
What happens if you disable AX mode on 2.4Ghz?
How many devices do you have on the 2.4Ghz network?
Do you need TPIK enabled on 2.4ghz?
Try channel 1 or 11 on 2.4Ghz
- Netduma-FraserDec 16, 2022NetDuma PartnerWhen it next occurs could you connect to the interface via ethernet or 5GHz, download the log from the System Information page and post it here please?
- polscifreakFeb 16, 2023Guide
Sorry it took so long. It is currently happening. I haven't rebooted yet. My 2.4 is down. 5 works as well as wired.
Log is attached as pdf, as it well exceeds the limit.
