polscifreak
Dec 15, 2022Guide
XR1000 2.4 Stops working
I bought an XR1000 a couple of years ago and haven't had any issues until recently. For about the last two months, the 2.4 band will stop working and nothing can connect to it. Rebooting the router...
Dec 16, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
How is the wifi settings configured?
What do you have connected to the 2.4Ghz radio?
For about the last two months, the 2.4 band will stop working and nothing can connect to it. Rebooting the router fixes it.
I've tried several firmware versions and have the same result.
Any ideas?
michaelkenward
FURRYe38 wrote:
Is there an echo in here?
