polscifreak
Dec 15, 2022Guide
XR1000 2.4 Stops working
I bought an XR1000 a couple of years ago and haven't had any issues until recently. For about the last two months, the 2.4 band will stop working and nothing can connect to it. Rebooting the router...
polscifreak
Dec 16, 2022Guide
For my modem, I'm using a Netgear CM1000v2.
WIFI Settings:
2.4 GHz
Enable AX
Enable SSID Broadcast
Enable 20/40 MHz Coexistence
Auto Channel
Mode: up to 600 Mbps
Transmit Power: 100%
WPA-Personal [TKIP] + WPA2-Personal [AES]
5 GHz
Channel:36
Mode: up to 4800 mbps
I don't seem to be having any issues with the 5 GHz band.
On the 2.4, I mainly have my smart home devices connected. Everything else I try to get on the 5. When the issue occurs, even my phone will not connect to the 2.4, but can connect to the 5.
In range, I only see two other wifi networks.
Dec 16, 2022Guru - Experienced User
What happens if you disable AX mode on 2.4Ghz?
How many devices do you have on the 2.4Ghz network?
Do you need TPIK enabled on 2.4ghz?
Try channel 1 or 11 on 2.4Ghz
