Tkbuc
Nov 24, 2022Guide
XR1000 2.4Ghz Keeps Failing to Obtain IP Address
Man this is so frustrating. Router was working great until a week ago when I try to connect new devices to my 2.4ghz channel, they can't and I get a "Failed to Obtain IP Address" for that channel. ...
Tkbuc
Nov 25, 2022Guide
I am not using Smart Connect. It is disabled. Yes, I am able to see the device in Device Manager. I don't know how to assign it a static IP. If I did, and it connected, what would that mean?
Netduma-Liam
Nov 25, 2022NetDuma Partner
You can do it from Settings -> Setup -> LAN Setup.
If that works, it must be a DHCP issue as the error is suggesting. Give that a try and let us know how you get on.
- FURRYe38Nov 25, 2022Guru - Experienced User
Recommend setting the default DHCP IP address pool range to the following: 192.168.#.100 to 192.168.#.200.
