PapaLung
Jun 16, 2022Apprentice
XR1000 2.4ghz not connecting to smartphones
2.4ghz will connect then disconnect immediately or it will tell me that the password is incorrect when it definitely is not. The signal strength shows full bars also. I've tried randomized and phone m...
Netduma-Liam
Jun 16, 2022NetDuma Partner
Is this only a problem on smart phones, or are other devices having issues with the 2.4GHz too?
Is the router next to any other electrical devices, if so could you move them away?
For example, any IoT devices or bridges for those devices can cause interference.
