PapaLung
Jun 16, 2022Apprentice
XR1000 2.4ghz not connecting to smartphones
2.4ghz will connect then disconnect immediately or it will tell me that the password is incorrect when it definitely is not. The signal strength shows full bars also. I've tried randomized and phone m...
PapaLung
Jun 20, 2022Apprentice
I have the router far enough from anything that could remotely even begin to cause any kind of interference. It's in the same exact spot my xfinity B7 was and it never had an issue. I'm not running anything like surveillance cameras or lights ect. The 2.4 ghz is set at wpa2 already and ax is enabled. My modem is a nighthawk cm2050v, from what I've been told, should be able to handle this router.
Netduma-Fraser
Jun 21, 2022NetDuma Partner
What devices are you having the issues on specifically? For example, iOS devices have an option enabled by default that randomizes their MAC address and that can cause issues.
Judging by your comments you disabled Smart Connect is that right?
