ahmer_ali78677
Nov 10, 2024Aspirant
xr1000 5g wifi not showing on iphone 16 pro max
My Netgear XR1000 5G WiFi is not showing up on my iPhone 16 Pro Max unless I restart the phone. I have also tried connecting with my iPhone 15 Pro Max and 14 Pro Max, but the network does not appear ...
Netduma-Fraser
Nov 10, 2024NetDuma Partner
Change the WiFi mode for 5GHz to 2400Mbps, apply, reboot, then check please
ahmer_ali78677
Netduma-Fraser
I checked with a 600 Mbps, but it’s not showing.
- Netduma-FraserNov 10, 2024NetDuma PartnerSo it only seems to be iOS devices that can't see it, everything else can? Are all devices & the router from the same region or was the router or phones bought from/in a different country for example?
- ahmer_ali78677Nov 11, 2024Aspirant
Why does it show when I restart my iPhone, but its not showing on Samsung devices aswell? This suggests that it’s not an issue with the mobile device or iOS. The iPhone 16 Pro Max, which supports Wi-Fi 7, still doesn’t display it on either the Samsung or the iPhone.
- Netduma-FraserNov 11, 2024NetDuma PartnerAre all devices & the router from the same region or was the router or phones bought from/in a different country for example?
