twitchie1
May 12, 2022Tutor
XR1000 5ghz wifi speeds capped 300mbps? even though i had 1gig up/down now
Hi i recently upgraded from 300mbps up/down to 1gig up/down and my ethernet is hitting 900+ up/down but my wifi 5ghz connection on my phone will only top out around 300-325mbps which is what it use t...
- May 12, 2022That's correct, that puts the speed it's getting at about 660Mbps instead of what the speedtest is reporting. If speedtest was correct than you would only be able to download at ~33MB/s so I think you can ignore the speedtest results
Netduma-Fraser
May 12, 2022NetDuma Partner
What is your phone model? It's quite possible that's the maximum it can achieve.
What do you mean DumaOS is slow and crowded exactly?
Try these suggestions:
Disable Smart Connect, give 2.4/5GHz different names and apply - you'll want to connect to 5GHz specifically for speeds
Use a WiFi analyzer to find the least congested channel and change to that
Ensure it's in an elevated position - not on a metal surface
Ensure there aren't any electrical / wireless devices e.g headphones etc within close proxity ~3 feet if possible
Set the antennae to this position _ | | _
twitchie1
May 12, 2022Tutor
The screen shots from my test was done on my PC wired then switched to WIFI 5ghz have 2.4Ghz disabled, realized that it could be my phone so i eliminated that variable...
Did the antennas _| |_
Ran a Wifi analyzer best channel was 44 it is on channel 44
Phone is a Samsung s21
router is on a wooden counter free and clear from wires metal or electrical
Smart connect is disabled
Have tried disabling QoS also
Have done 3 resets and new setups
The slow Dumas i feel like its very slow clicking on things and waiting it feels dull and slow like its over crowded i guess
Also thank you for your help thus far
- Netduma-FraserMay 12, 2022NetDuma PartnerHow did you disable QoS exactly - by selecting Never or disabling it fully from the Congestion Control menu? What firmware version are you on currently? What browser/device are you using to access the interface?
- twitchie1May 12, 2022Tutor
I disabled it by doing both the congestion menu and selecting Never
Firmware XR1000 1.0.0.64_1.0.49
Browser is Firefox latest version its on my PC windows 10
Is it possible the Wifi Speed tests just are not reliable? i was able to download at 79 MB\s wireless thats over 600 mbps?
- Netduma-FraserMay 12, 2022NetDuma PartnerThat's correct, that puts the speed it's getting at about 660Mbps instead of what the speedtest is reporting. If speedtest was correct than you would only be able to download at ~33MB/s so I think you can ignore the speedtest results
