AvgExile
Oct 22, 2022Aspirant
XR1000 Adblock Issues
Hi Everyone, I have been trying to get the Adblocker working on my XR1000 today and to no avail. I've read Netgear KB on using the link to the default list but this doesn't block any ads on...
Netduma-Fraser
Oct 22, 2022NetDuma Partner
Could you provide a screenshot of your Adblocker page please so we can take a look? Are you using Armor?
AvgExile
Hi,
Please see screenshot below,
I've been testing and it looks like it does block traffic, but for some reason I'm still seeing all the ads.
Thanks!
- Netduma-FraserOct 22, 2022NetDuma PartnerCould you provide some examples of places where you're noticing the ads? Are you using Armor?
- AvgExileOct 22, 2022AspirantHi,
I am noticing these ads on pages such as Facebook, YouTube ads before and during videos.
Also alot of webpage popups etc that were blocked before by my browser extension now pop-up when using the DumaOS defaults.
I'm not using Armor. - AvgExileOct 22, 2022Aspirant
Hi,
Just to confirm,
I see these ads, and then when for example I click on them and it redirects like it should so the page doesn't load.
So the AdBlock itself actually works with redirecting when you click on the ad, it just unfortunately still shows the ad.
Thanks.
- Netduma-FraserOct 22, 2022NetDuma PartnerYouTube Ads won't be blocked as they're served from the same URL I believe as the video so if you blocked them you'd also block the video. The latter is normal, when you search in Google you'll see the ads but they're also legitimate search results so that's why they show but then the link behind it is blocked.
When you upgraded to the latest firmware did you do a factory reset afterwards?
