AvgExile
Oct 22, 2022Aspirant
XR1000 Adblock Issues
Hi Everyone, I have been trying to get the Adblocker working on my XR1000 today and to no avail. I've read Netgear KB on using the link to the default list but this doesn't block any ads on...
Netduma-Fraser
Oct 22, 2022NetDuma Partner
Could you provide some examples of places where you're noticing the ads? Are you using Armor?
AvgExile
Hi,
Just to confirm,
I see these ads, and then when for example I click on them and it redirects like it should so the page doesn't load.
So the AdBlock itself actually works with redirecting when you click on the ad, it just unfortunately still shows the ad.
Thanks.
- Netduma-FraserOct 22, 2022NetDuma PartnerYouTube Ads won't be blocked as they're served from the same URL I believe as the video so if you blocked them you'd also block the video. The latter is normal, when you search in Google you'll see the ads but they're also legitimate search results so that's why they show but then the link behind it is blocked.
When you upgraded to the latest firmware did you do a factory reset afterwards?- AvgExileOct 22, 2022Aspirant
Hi,
By the very nature of my other Adblocks I've had, these do stop the YouTube video ads as stated.
I would expect any adblocker provided it blocks the correct AD Domain to block these as well.
Seems as though there must be something in a list that I could add. Any Suggestions? Would really like to use this network wide for the family rather than have to install apps on phones and blockers on the PCs instead.
I have done a factory reset afterwards as well.
Thanks.
- Netduma-FraserOct 23, 2022NetDuma PartnerThose will have been browser based Adblockers which would have been able to block more easily, when it's based on the network it is harder - it's very much something we're still working on and really want to find a workaround for. That's what I mean, the ad is served from the same domain as the video.
When you used other lists like easylist did you add it in the same way, as an online list? Also try downloading our file and then uploading it to the router and adding it that way
