kevinMario
Oct 05, 2025Aspirant
XR1000 Admin Password Reset loop
Just happened today Repro steps: Went to the Admin home ( 192.168.1.1 ) Got shown this screen Entered S/N Got asked 2x Security Questions, answered correctly Got show...
Netduma-Fraser
Oct 05, 2025NetDuma Partner
Your browser may have cached an old login and is trying to log you in automatically. Try using an incognito window does it show you the login box and can you login successfully that way?
kevinMario
Oct 23, 2025Aspirant
It's not the cache, using incognito from 3 different browsers ( Edge, Chrome, Firefox ) still gives me the same error.
- Netduma-FraserOct 24, 2025NetDuma Partner
Are you entering quite a complex password with different symbols? If you just set the password as password are you able to get through then?
- kevinMarioOct 30, 2025Aspirant
Nah, the password is pretty simple.
Alphanumeric with 1 Capital and a few numbers - not even using any special characters.
- Netduma-FraserOct 31, 2025NetDuma Partner
Factory reset, set it back to password, that should get you in to the interface after, then upgrade or re-upgrade to the latest firmware version, once that's completed factory reset again and see if it works better then
