kevinMario
Oct 05, 2025Aspirant
XR1000 Admin Password Reset loop
Just happened today Repro steps: Went to the Admin home ( 192.168.1.1 ) Got shown this screen Entered S/N Got asked 2x Security Questions, answered correctly Got show...
kevinMario
Oct 23, 2025Aspirant
It's not the cache, using incognito from 3 different browsers ( Edge, Chrome, Firefox ) still gives me the same error.
Netduma-Fraser
Oct 24, 2025NetDuma Partner
Are you entering quite a complex password with different symbols? If you just set the password as password are you able to get through then?
- kevinMarioOct 30, 2025Aspirant
Nah, the password is pretty simple.
Alphanumeric with 1 Capital and a few numbers - not even using any special characters.
- Netduma-FraserOct 31, 2025NetDuma Partner
Factory reset, set it back to password, that should get you in to the interface after, then upgrade or re-upgrade to the latest firmware version, once that's completed factory reset again and see if it works better then
