stigjones
Apr 09, 2021Aspirant
Xr1000 and EAX80 not working
Hi any one out there running XR1000 or XR700 with a range extender EAX80 I am trying to configure and going through the setup wizards can see the two networks on the XR1000 once setup it’s like the ro...
Apr 10, 2021Guru - Experienced User
The EAX80 is a mesh extender.
Meaning that if you set it up using wps or the default settings in the installation wizard, it uses the same SSID (name) as the router.
this allows devices to roam between the 2 networks as needed without you having to manually switch it.
Is this how you setup the device?
stigjones
Apr 10, 2021Aspirant
I have been using web browser you can see the main networks, select and enter passwords, connect and it’s like the router just dose not want to connect. And the router light on it ext dose not light up.
- Netduma-FraserApr 11, 2021NetDuma PartnerHow did you try to connect them together initially, WPS, app?
- plemansApr 11, 2021Guru - Experienced User
did you try setting it up using wps?
