joem1541960
Feb 15, 2023Aspirant
XR1000 and the creation of a "whitelist"
I have an XR1000 and I wanted to know if it allows me to create a "whitelist" of permitted MAC IDs that may access the Wifi, to the exclusion of all other MAC IDs?
Netduma-Liam
Feb 16, 2023NetDuma Partner
I'm afraid this is not currently possible. If you don't mind me asking, what's the reason for needing such a feature? Are you having a specific problem?
- joem1541960Feb 16, 2023Aspirant
I do not want any stranger to pass by my house, sit in a car near my house and sign onto my WiFi. The SSID/password is the only line of defense against that intrusion. I know I able to not broadcast the SSID. NETGEAR uses a software package called Genie software and it does show it can allow only specific MACs to access the network. If not the XR1000, can you tell me about any other NETGEAR that uses Genie?
- Netduma-FraserFeb 16, 2023NetDuma PartnerAs long as you have a strong password - capital letters, numbers, symbols etc it is very unlikely someone would be able to connect to the WiFi but I do understand. We (Netduma) can only advise on the Pro Gaming range so you'd need to do some extra research/post in one of the other sub forums to find that out.
- FURRYe38Feb 16, 2023Guru - Experienced User
FYI, even hidden SSID broadcasts can be seen and found with a simple or good wifi scanner.
Not everyone is passing your house or sitting out on the street trying to hack your wifi. As suggested, use a good complex SSID password and you'll be fine.
