eding
Oct 26, 2024Aspirant
Xr1000 and Ubiquiti Air Cube
Whats the best way to connect my modem/router to a new router i bought? I got this router hoping to reach further as i spend most of my time outside. I read a bit about how you're not supposed to hav...
Lobo707
Nov 26, 2024Aspirant
Hey thanks for the reply! I talked to ISP and asked them if putting the AC in bridge mode was something they could do. They said adding the xr would slow down the whole system and suggested I'd get best results if i add another link in...?
Like, isn't that what I'm trying to do??
Also, I did see several reviews saying aircubes aren't that great for bridge mode anyway.
I'm kinda stuck. I can't even have fun gaming because I get constant lag and matches take forever to load.
Netduma-Fraser
Nov 26, 2024NetDuma Partner
It's not going to slow down the whole network, by link in do they mean literally adding another internet line in?
You don't need bridge mode, just the DMZ option I mentioned will be fine
