rounder
Jul 31, 2021Aspirant
XR1000 broken upnp, no vpn , no firmware updates
HI there, For a supposeduly flagship product there are no firmware updates for this router since last year! It seems its abandoned. No betas as well at all. I tried v1.0.0.53 but that versi...
Netduma-Fraser
Jul 31, 2021NetDuma Partner
You can't have two devices in the DMZ, Open NAT will be fixed for the next version. HybridVPN isn't missing it was just not included on this router, it may be included in future versions. We're working on improving the reporting of Benchmark, it doesn't mean those are the speeds and ping under load that you have. A new version should be available relatively soon
