fregapple
Feb 17, 2025Aspirant
XR1000 Bufferbloat until I cut network connection breifly
I have been having an issue with my Router for a while now. Been trying so many different things to get it back to where it was. So for testing I have Ping Plotter pinging a Dota 2 server near me....
fregapple
Feb 20, 2025Aspirant
It is worth mentioning, that I have tried many different configurations with CC and Traffic prioritization.
It never makes a difference, in fact, while the issue is happening, it is worse to have CC enabled.
Currently it is turned off.
Netduma-Fraser
Feb 20, 2025NetDuma Partner
It seems to me that you're being bombarded by connections from China which could well be causing the issue. Do you have a dynamic or static public IP address? If you have dynamic then I would unplug your modem for 10 minutes, then plug in, see if you get a different IP address and monitor whether the issues happen again
- fregappleFeb 20, 2025Aspirant
I have a static IP from my ISP
- Netduma-FraserFeb 20, 2025NetDuma PartnerIn that case I'd suggest contacting them and have them change the address if possible and then monitor it
So I have gotten my static IP swapped. I am now not getting swamped by China IP's 60 requests a minute.
I will monitor this a little more before marking as solved. But so far the router isn't throttling the connection to my server randomly yet. So fingers crossed.
