fregapple
Feb 17, 2025Aspirant
XR1000 Bufferbloat until I cut network connection breifly
I have been having an issue with my Router for a while now. Been trying so many different things to get it back to where it was. So for testing I have Ping Plotter pinging a Dota 2 server near me....
fregapple
Feb 20, 2025Aspirant
I have a static IP from my ISP
Netduma-Fraser
Feb 20, 2025NetDuma Partner
In that case I'd suggest contacting them and have them change the address if possible and then monitor it
- fregappleFeb 20, 2025Aspirant
So I have gotten my static IP swapped. I am now not getting swamped by China IP's 60 requests a minute.
I will monitor this a little more before marking as solved. But so far the router isn't throttling the connection to my server randomly yet. So fingers crossed.
Annnnnnnnnnnnnnnnnnnnnnnnnnnnnnd No.
It has not solved it at all.
It is as if QoS just turns on and hard limits my server to 100mbps until I disrupt the service briefly.
I fully disabled QoS. But yet this shows up in the logs?
Using disabled(NOP) QoS subclass
- Netduma-FraserFeb 20, 2025NetDuma PartnerCan you provide a screenshot of how you have the QoS page set please? What is the actual modem/router the XR is connected to to get internet?
