fregapple
Feb 17, 2025Aspirant
XR1000 Bufferbloat until I cut network connection breifly
I have been having an issue with my Router for a while now. Been trying so many different things to get it back to where it was. So for testing I have Ping Plotter pinging a Dota 2 server near me....
Netduma-Fraser
Feb 20, 2025NetDuma Partner
In that case I'd suggest contacting them and have them change the address if possible and then monitor it
fregapple
Feb 20, 2025Aspirant
So I have gotten my static IP swapped. I am now not getting swamped by China IP's 60 requests a minute.
I will monitor this a little more before marking as solved. But so far the router isn't throttling the connection to my server randomly yet. So fingers crossed.
- fregappleFeb 20, 2025Aspirant
Annnnnnnnnnnnnnnnnnnnnnnnnnnnnnd No.
It has not solved it at all.
It is as if QoS just turns on and hard limits my server to 100mbps until I disrupt the service briefly.
I fully disabled QoS. But yet this shows up in the logs?
Using disabled(NOP) QoS subclass
- Netduma-FraserFeb 20, 2025NetDuma PartnerCan you provide a screenshot of how you have the QoS page set please? What is the actual modem/router the XR is connected to to get internet?
It is connected to a PON for our FTTP network.
Here is the screenshot:
- Netduma-FraserFeb 21, 2025NetDuma PartnerDid you always have it set to never when the issue occurred? Have you setup Traffic Prioritization further down the page?
