Sureshot08
Nov 24, 2022Tutor
XR1000 cant connect to geofilter and pingmap
I all of a sudden am not able to use or connect to the duma os features geofitler or heat ping map. I have the latest version XR1000 1.0.0.64_1.0.49 have cleared my cache and cant find anyway to get ...
Nov 25, 2022Guru - Experienced User
Be sure to clear out all browser caches before entering the routers web page.
Might try FireFox as well...
Sureshot08 wrote:
I all of a sudden am not able to use or connect to the duma os features geofitler or heat ping map. I have the latest version XR1000 1.0.0.64_1.0.49 have cleared my cache and cant find anyway to get the web browser to work. I am currently using the edge browser
- Sureshot08Nov 25, 2022TutorThank you, I'll give Firefox a shot
I am unable to access both the geofilter and ping heatmap. every other aspect of the browser and UI work fine but those two either try and load forever or produce the error message rapp wont load wait a minute. I am on version XR1000 1.0.0.64_1.0.49
Heres what ive tried from some other posts:
Setting the rapp retry limit to 5
Downgrading firmware to a few different versions
Using both Microsoft Edge and Chrome
Deleting cache and cookies
Hard resetting router
- Netduma-LiamNov 25, 2022NetDuma Partner
Thanks for all the information.
Which firmware versions did you try downgrading to out of interest?
Does rebooting the router temporarily resolve the issue?
- Netduma-FraserNov 25, 2022NetDuma PartnerIf that doesn't work, reboot the router then wait 2 minutes before accessing
