rav3ndk
Mar 31, 2023Tutor
XR1000 can't connect wireless printer Canon MF635cx
Hi, Ever since switching to my new XR1000 router, I can't connect the printer. Sometimes directly after connecting it to the 2.4GHz network it responds - but only shortly - and after a few minutes i...
- Mar 31, 2023
Have you tried disabling AX mode on the routers web page under Basic/Wireless Settings?
What channels are you using? 1, 6 or 11 is recommended.
Be sure the FW on the printer is up to date.
Contact Canon for additional help and information regarding there product.
Does the printer connect using ethernet wire cable to the router?
rav3ndk
Mar 31, 2023Tutor
See attached file in other reply for my WiFi settings.
Disabling AX mode on an AX router? Why buy an AX router then. But I can certainly try it too see if it helps.
Printer drivers & firmware are up to date.
I am contacting Netgear, because functionality broke with their product being introduced. Did you miss, that when I connect my old router it works again?
Mar 31, 2023Guru - Experienced User
See if disabling AX mode helps. Some devices may not be able to handle having this mode being enabled. This would be a printer issue, not a NG router issue.
Also try enabling 20/40Mhz Co-existence as well.
One test to try as a quick test, disable WPA security temporarily on the router and connect the printer to the router to see if it keeps connected or not. Re-enabled WPA2 and AES after testing or try mixed mix mode WPA and WPA2 and test.
If other devices connect fine to the router and this one device doesn't, would be a issue between the router and your printer. Could be some wifi incompatibilities on the printer and the router.
Try connecting the printer via ethernet as well.
- rav3ndkMar 31, 2023Tutor
Hi FURRYe38,
Thanks for your suggestions. I disabled AX mode and now the printer connects and stay connected 🙂
I guess I will just have to live with this until it's time to replace printer.
It would be nice though, if one could disable AX mode only for 2.4GHz and leave it enabled on 5.0GHz. That's one for the NetDuma / NetGear guys I guess 🙂
Thanks a lot for your suggestions. I was getting so frustrated that I was at a point of returning it. So you saved me the trouble. THANKS again.
- FURRYe38Mar 31, 2023Guru - Experienced User
Ya, You get that on some other NG routers, Orbi and RAX.
Something that you can do too with the printer, connect it via ethernet.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
