rjswayer
Jul 29, 2022Tutor
XR1000 Connected to internet, Ethernet is working, wifi comes and goes
I've been having trouble with my wifi connection over the last few weeks. My router indicates that it is connected to the internet, but the wifi connection will constantly disconnect and reconnect on my TV, computer, and iPad. I will then switch over to my console (it's hardlined) and have no issues. I've rebooted several times over the last week, and nothing has fixed this. I'm trying to avoid a factory reset as I don't want to have to reset all my settings. Is there anyone else that has experienced this?
have you noticed a difference from 2.4ghz to 5ghz?
What modem/gateway is the router connected to?
- rjswayerTutor
I have a Netgear CM1000-100NAS for my modem, ISP is Xfinity, and the 5ghz is turned off due to interference.
To build more on Xfinity. They replaced all the cable ends in my apartment and replaced a bad cable to the telecom room from my apartment yesterday and everything is good on their end. I'm reading 500+Mbs at the modem for connection speed with upload of 20 and ping at 15.
My 5ghz is turned off because I noticed drastic network speed changes when devices were connected to the 5ghz side, so I disabled it without issue 3 months ago when I first purchased the router. Everything was great until the last week or so.
- Netduma-FraserNetDuma PartnerThere may be some neighboring WiFi networks that have popped up around you, use a WiFi analyzer to find the least congested channel and change to that to see if it makes it more stable for you.
