Taurus2313
Jan 22, 2023Guide
XR1000 Connection issues-Again....
Hey guys...Well I am back again with the same issue I had about a month ago unfortunately. My previous thread on this issue (link below ->XR1000 Connection issues-Please help!) should be here in thi...
Netduma-Fraser
Jan 28, 2023NetDuma Partner
Sorry to hear that but I do understand your position and frustration, I can only hope that you may consider it again in the future, perhaps after a few firmware iterations. Thank you for letting us know.
Taurus2313
Jan 28, 2023Guide
Thank you so much for understanding.🙏 I just wanted to say thanks to all of you who offered input and advice trying to help me find a solution in the meantime. It was frustrating to keep trying everything over and over and not getting any positive results. I wish things would have turned out different, so thanks again to everyone that offered your time and input on this thread. It was much appreciated!
- FURRYe38Jan 28, 2023Guru - Experienced User
Something you might try as last resort, take the router to a different location, friend, nieghbor or family member and see if the problem follows.
Something to keep in mind for your next router, install a laptop cooler fan under the router. Keeps it cool and helps stave off long term head damage and helps HW last longer. I keep one under mine for 24/7 cooling.
