Taurus2313
Nov 29, 2022Guide
XR1000 Connection issues-Please help!
Okay I posted in another forum but it got no responses at all. I don't know what else I need to do. I have been having an issue with this router for week now. I keep getting "cannot obtain IP add...
- Nov 29, 2022
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Most ISPs use DHCP for the WAN side so no FIXED IP configurations are not needed here from the ISP. Check with the ISP if you need to see if this is required by them.Your model Arris model will be telling as well.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
Nov 29, 2022Guru - Experienced User
