Taurus2313
Nov 29, 2022Guide
XR1000 Connection issues-Please help!
Okay I posted in another forum but it got no responses at all. I don't know what else I need to do. I have been having an issue with this router for week now. I keep getting "cannot obtain IP add...
- Nov 29, 2022
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Most ISPs use DHCP for the WAN side so no FIXED IP configurations are not needed here from the ISP. Check with the ISP if you need to see if this is required by them.Your model Arris model will be telling as well.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
Taurus2313
Nov 29, 2022Guide
On the 2.4ghz band if I change that from the factory name & password SSID to the one that I have been using for the past 1yr 9 months then yes whenever the devices come online to connect to that 2.4ghz SSID it knock everything offline and I get the cannot obtain IP address issue across the board for both Wi-Fi 2.4ghz and 5ghz bands..
Yes the one day I was able to get everything back up and going again I did have to update every 2.4ghz controlled device (Bulbs, Plugs, Cameras etc..) to the SSID all over again and it was an utter pain to do that. It took me almost all day to get it done and that is using the same SSID that they are tethered to for the past 1yr 9months..
After changing from the factory one back to the one I had been using. I hope that this makes sense..
Netduma-Fraser
Nov 29, 2022NetDuma Partner
Could you provide the SSID name you're using or if you're not comfortable with that, is it just alphanumeric or are you using symbols in the name as well? If you are using symbols, what symbols are you using?
- Taurus2313Nov 29, 2022Guide
It is one capital letter at the beginning and the rest are all lowercase with a single number at the end like so for example..
Captainkangaroo2
No symbols in either SSID's or passwords..
I did reply back to Furrye38 but it wouldn't let me post it saying I was flooding the system or something like that. I will try to post my answers to his questions "Again" as well.
- Netduma-FraserNov 29, 2022NetDuma PartnerHow many characters is the password - is it quite long or similar to the default? Are you using Smart Connect or do you have that disabled? Could you please disable OFDMA for 2.4GHz apply, then change the SSID and see if it still causes the issue?
- Taurus2313Dec 01, 2022Guide
10 Characters in the PW. Am not using nor have I ever used Smart Connect as I like having 2 separate bands because of most smart home devices only will connect to 2.4ghz band. I don't want anything that would connect to 5ghz to switch to that 2.4ghz band automatically.
I was able to get the router up and running again for now. I did follow FURRYe38 and change the IP Pool from 1-254 to 100-200 and I am hoping that made the difference. If there is a change and it goes down again I will certainly try what you suggested.
Thanks so much for the responses. It is VERY appreciated and was very helpful. If I have issues again I will come back here to update.
