howmaybesgo
Apr 12, 2023Aspirant
XR1000 continuous connectivity issues (no internet for devices)
I have had some weird issues where devices can't connect to the 2.4 ssid and now this morning almost all devices were unable to connect to the internet (wifi and hardline). Router showed good connec...
Apr 12, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
howmaybesgo
Edit: Using CAT6
Modem: Arris Surfboard SB8200
Estate lot neighborhood so I may see neighbors but they are not close enough to connect to.
I think 2.4 is auto but not sure about 5.
I can't even access the router currently. The issue is not isolated to wifi as my personal PC is hardwired and it also was seeing this issue. I was able to ping 8.8.8.8 but could not load any web sites. That being said, my work laptop which is on wifi seemed to be the only PC that was able to connect to the internet (no static IP assigned). I changed the DHCP pool to .2-.240 and started setting static IP assignments for other PC's on the network and that seemed to work.
Also noticed when I switched my personal PC over to wifi for testing, there was a duplicate lease on the .37 address. Was assigned to my PC and my home security base station. When the PC was hardwired it pulled the .11 which wasn't a duplicate but the router did not show it online. Again, able to access router and ping 8.8.8.8 but not able to load web sites.
I won't be able to perform a factory reset until after work as I don't want to break what is currently working. Able to ping the router but cannot access the router config by browsing to its IP. Get the message "this site can't be reached".
- FURRYe38Apr 12, 2023Guru - Experienced User
- howmaybesgoApr 12, 2023Aspirant
Added this as edit but will include as response.
Using CAT6
Modem: Arris Surfboard SB8200Estate lot neighborhood so I may see neighbors but they are not close enough to connect to.
I think 2.4 is auto channel but not sure about 5.- FURRYe38Apr 12, 2023Guru - Experienced User
I've heard of other SB8200 users having issues with there modems on there ISP services. Please first ensure the ISP service signal on the coax line up to the modem is in good working condition and to spec for the modems Mfr specifications.
When you can, try changing to manual channels, after you can do a factory reset and setup from scratch. Also don't set any custom DNS on the router, use auto detect initially first.
Also would set 40Mhz only channel width as well, Under Advanced Tab/Advanced Settings/Wireless Settings
What all do you have connected to the router, wired and wireless devices?
