charleyshf
Oct 21, 2021Tutor
XR1000 Disable 2.4ghz band only?
Hello, XR1000 netgear router I couldn't find any option but is there a way I can diable the 2.4ghz radio without disabling the 5ghz radio on this? Thanks
- Oct 21, 2021Yes, you'll need to disable Smart Connect first in WiFi Settings and then you can disable 2.4GHz fully from Settings > Advanced > Advanced WiFi Settings
Netduma-Fraser
Oct 21, 2021NetDuma Partner
