Cljack3
Dec 20, 2022Tutor
XR1000 doesn’t work with IP V6 pass through
Netduma Team the XR1000 doesn’t work with IP V6 pass through. This is a known issue reported for over a year. My XR 500 works fine. I simply swap the 2 and boom works on the XR 500. The XR 1000 loses...
Netduma-Fraser
Dec 20, 2022NetDuma Partner
As above it's something for NG to look into but have you tried the other methods available for IPv6 in case one of those works better on the 1000?
Cljack3
Dec 20, 2022Tutor
I’ve tried the same configuration on both routers pass through and auto detect. This configuration works fine for the XR 500. If I switch to the newer XR 1000 it longer works. I’ve done a factory reset, had the internet company (Comcast Infinity) reset my cable modem, no dice. I have my device connected via lan Ethernet cable that was tested. IP V6 does appear to work better on when connected to XR 1000 WiFi. IP V6 works fine on the XR 500 WiFi and Ethernet connections, which leads me to believe that something’s wrong with the XR 10000.
At this point, I’ve given up on Netgear and moved on to Asus. They provide regular firmware updates for fixes and security vulnerabilities. Sometime Netgear takes over a year to release firmware. This put’s the security of my home network in an undesirable situation. I’m not blaming the Netduma team since it’s clearly Netgear missing the ball on customer support.
- Netduma-FraserDec 22, 2022NetDuma PartnerSorry to hear that, I do hope once a new firmware is out that you'll consider trying it again
