Jaddjitsu
Jan 26, 2023Tutor
Xr1000 Download/Upload speeds
So i'm running the latest firmware on the xr1000. I have done the resets, I have a Cat7 cable from modem to router. When I run speed test on ookla after my router has been restarted I get 947 or so...
- Jan 26, 2023
So the issue ended up being with my isp. They had recently moved my modem onto a different server thus causing the issues i was having. They gave me a new modem and put me on my old server i was originally on and now its working like a champ.. Thank you for the advice and help.
Netduma-Liam
Jan 26, 2023NetDuma Partner
Do you know if you use PPPoE, VLAN or DHCP identifiers in order to get connected to the internet?
Jaddjitsu
Jan 26, 2023Tutor
DHCP
- Netduma-FraserJan 26, 2023NetDuma PartnerHow have you disabled QoS exactly by setting Congestion Control to Never or disabling it fully from the Congestion Control 3 horizontal line menu top left of the panel?
- JaddjitsuJan 26, 2023Tutor
I have done it both ways, with same results.
- Netduma-FraserJan 26, 2023NetDuma PartnerWhat is the model of your modem? Are ALL devices connected to the XR?
