Jaddjitsu
Jan 26, 2023Tutor
Xr1000 Download/Upload speeds
So i'm running the latest firmware on the xr1000. I have done the resets, I have a Cat7 cable from modem to router. When I run speed test on ookla after my router has been restarted I get 947 or so...
- Jan 26, 2023
So the issue ended up being with my isp. They had recently moved my modem onto a different server thus causing the issues i was having. They gave me a new modem and put me on my old server i was originally on and now its working like a champ.. Thank you for the advice and help.
Netduma-Fraser
Jan 26, 2023NetDuma Partner
Keep us posted!
Jaddjitsu
Jan 26, 2023Tutor
- Netduma-FraserJan 26, 2023NetDuma PartnerThat's great to hear, thank you for the update!
- FURRYe38Jan 26, 2023Guru - Experienced User
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. đĄ
