BIGRIFF
Jan 30, 2026Aspirant
XR1000 dropping out every couple of hours
Im getting the same issue and i dont know what to do to fix it. I have reserved all my devices from .2 to .49 and set the DHCP range from .50 to .99 and yet im still experiencing a dropout which d...
BIGRIFF
Feb 02, 2026Aspirant
What do you mean it should disconnect me from the interface? I have used an XR500 for like 3 years and have never been disconnected from doing a speedtest within the interface. Not only am I being disconnected from the interface with the 'connection benchmark' utility, but if I run a speed test on for example Ookla or Google Speed test the same message is shown to me. Makes me think the XR1000 is struggling to a simple speed test.
Also do you have any info on the "Thursday, Jan 01,1970 00:00:00" message being printed in the logs over and over?
Netduma-Fraser
Feb 02, 2026NetDuma Partner
By design it will disconnect you from the internet, not the interface when running the test. Interesting, what time does the System Information page show? If it is the same it could be causing the issues, make sure the time zone is correct/adjust for DST if needed and verify it is correct, reboot from the interface, wait 4 minutes then see if you can reproduce the issue
