BIGRIFF
Jan 30, 2026Aspirant
XR1000 dropping out every couple of hours
Im getting the same issue and i dont know what to do to fix it. I have reserved all my devices from .2 to .49 and set the DHCP range from .50 to .99 and yet im still experiencing a dropout which d...
Feb 03, 2026Guru - Experienced User
Updated FW on my XR1000v1 yesterday to v1.0.2.86. Factory reset and setup from scratch using .100 to .150 default IP address pool range.
Have a few static IP addressed devices out side of this pool range. Couple of other devices dymanic IP addressed from with in this pool range.
System as been online and solid since...No drops seen.
- FURRYe38Feb 09, 2026Guru - Experienced User
6 Plus up days on my XR1000v1:
Firmware Version V1.0.2.86_2.1.40
Basic Information
CPU Load
CPU1: 15.32% CPU2: 15.28% CPU3: 0.09%
Memory Usage (Used/Total)
429MB/497MB
Flash Usage (Used/Total)
125.35MB/256.00MB
Network Session (Active/Total)
743/65535
System Uptime
6 days 16:14:37
