Readyplayer2
Nov 12, 2024Aspirant
Xr1000 DumaOS 3.0 how do you know what server you connected to Destiny 2
So, I decided to try Geo-filtering on Destiny 2 again. I understand you can’t filter players. However, you should be able to filter servers. I put the radius around my servers that are closest to me. ...
Readyplayer2
Also what is ping assist? I’m confused on what that actually is/does? I circle the two servers near me. They are in Texas. Then I turn on strict mode and auto ping off so I can click anything that may be blocked. Because I disconnect from matches before they start and I don’t know exactly what’s blocked. So I wait to see.
Readyplayer2
Excuse I meant to ask what is auto ping? Because if it’s in I can’t allow or deny anything. But how does it help me or give me information?
- Netduma-FraserNov 12, 2024NetDuma PartnerYou don't appear on the map so it will be the host/server just misclassified.
I'm fairly confident they did some updates that prevented the Geo-Filter working so I don't think it will always work. However, disable strict mode as that will help filtering - you may get games outside your radius but that's the best you can do I think.
Auto ping automatically pings the host/server to provide you with ping information, it just prevents you having to click the server manually to ping.
Also if you change options while you're already on the game it won't work very well at all, disable strict mode then start up the game and see if it is any better.- Readyplayer2Nov 13, 2024AspirantOkay will try that. Question… so I know Bungie went to a hybrid system where you have to connect to their servers now. But, how do you actually know if the filtering is working. So, what I tend to do is start the geo filter. Circle around the servers I want, and then start Destiny 2. I can see a bunch of different stuff pop up on the map. A server always pops up all the way near New York and then disappears. I’m currently in Tx, and there’s always a huge icon right there. I figured that was me and I would be hosting the matches since Destiny is P2P. How do I know if you geo filter is actually working?
- Readyplayer2Nov 13, 2024AspirantAlso disable by strict mode would essentially render filtering useless then. That would just allow the game to pick any server at that point correct? Or host?
- Readyplayer2Nov 13, 2024AspirantDisabling strict mode wouldn’t that just render geo filtering useless? Because that allows the game to connect anywhere. The goal I would like is to host the match and play people near me for best ping and connection. I know Destiny changed things so that people couldn’t cheat and match their buddies, but I would assume you should still be able to force the host by geo-filtering, correct?
