Yessah
Aug 15, 2022Aspirant
XR1000 DumaOS Geo-Filter setup
Whenever I try to change my home location in the Geo-Filter section I get an error. I've rebooted from in the menu, hardware and removed any devices for filtering. It's stuck as the default Californi...
Yessah
I've tried all ways. I've picked manually and set by general address.
Netduma-Fraser
Aug 15, 2022NetDuma Partner
Has it ever worked - when did it first occur? Have you upgraded the firmware recently and if so did you do a factory reset? If you haven't done the reset please do so and see if it works.
