DK350Z
Jun 15, 2021Star
XR1000 DumaOS not loaded yet!
Hi, Firstly sorry if this has been answered before, however I have searched this forum and have not found a 'stable' solution. I purchased a XR1000 a while ago and appeared to set it up without p...
Netduma-Liam
Jun 15, 2021NetDuma Partner
Sorry to hear this, could you please try going to System Information -> Installed Rapps -> Click the three-line menu and change the number of retries to 5?
You may need to reboot the router after this, then let us know how you get on!
DK350Z
Jun 15, 2021Star
I'm afraid there is no System Information menu when I access using http://routerlogin.net/adv_index.htm, or should I be looking somewhere else? The attached image shows what I can access.
- Netduma-LiamJun 15, 2021NetDuma Partner
Hmm, OK, what's the exact make and model of your modem?
- DK350ZJun 15, 2021Star
It's a Netgear router, not a modem. It's the Nighthawk Pro Gaming Router. Model XR1000.
The address http://www.routerlogin.net and 192.168.1.1 can no longer access the DumaOS with the error "DumaOS not loaded yet!"
The only way to access is with http://routerlogin.net/adv_index.htm which appears to use a simple interface. I can't remember where I found this link, either somewhere in these forums or through other searches
My apologies, I'm referring to the upstream modem/router that the XR1000 is connected to. If there isn't one, what does the XR1000 connect to for internet access? An ONT perhaps?
