DK350Z
Jun 15, 2021Star
XR1000 DumaOS not loaded yet!
Hi, Firstly sorry if this has been answered before, however I have searched this forum and have not found a 'stable' solution. I purchased a XR1000 a while ago and appeared to set it up without p...
DK350Z
Jun 16, 2021Star
Hi Netduma-Fraser and Netduma-Liam,
Ok so I've factory reset both my Modem and XR1000. I then put the Modem back into Bridge mode, the XR is connected via LAN port. I then logged into XR successfully, completed setup and arrived to the DumaOS, Yeh! :-) I have gone to System Information -> Installed Rapps, and set retry attempts to 5. Restarted, waited about 3 minutes, logged back in and DumaOS is still working.
I'll monitor tonight and over the next couple of days to confirm it still works.
Thank you so much to you both for the support, very much appreciated!
- Netduma-LiamJun 16, 2021NetDuma Partner
OK awesome, thanks for letting us know!
- DK350ZJun 18, 2021Star
It's been a couple of days now, and unfortunnately I'm back to the beginning with "DumaOS not loaded yet!" showing up when I try to enter the webpage :(
I have tried Chrome and Edge, and I've cleared the browsers cache and I have rebooted the router, still no change. I'm not sure what else to try- Netduma-FraserJun 18, 2021NetDuma PartnerUpgrade to the same firmware, this will bypass the boot process and any issues there https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP once complete perform a factory reset and see if it works better after that.
