DK350Z
Jun 15, 2021Star
XR1000 DumaOS not loaded yet!
Hi, Firstly sorry if this has been answered before, however I have searched this forum and have not found a 'stable' solution. I purchased a XR1000 a while ago and appeared to set it up without p...
Netduma-Liam
Jun 16, 2021NetDuma Partner
OK awesome, thanks for letting us know!
DK350Z
Jun 18, 2021Star
It's been a couple of days now, and unfortunnately I'm back to the beginning with "DumaOS not loaded yet!" showing up when I try to enter the webpage :(
I have tried Chrome and Edge, and I've cleared the browsers cache and I have rebooted the router, still no change. I'm not sure what else to try
- Netduma-FraserJun 18, 2021NetDuma PartnerUpgrade to the same firmware, this will bypass the boot process and any issues there https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP once complete perform a factory reset and see if it works better after that.
- DK350ZJun 20, 2021Star
Hi Fraser,
I've tried the procedure in the link you've provided and can't seem to get it to work (I've tried a few times over tha last couple of days). I'm always getting "connect request failed" after about 20 seconds or so. I'm assuming I'm not doing steps 7 to 12 correctly and the router is not going into the correct state to accept firmware. I'm not sure what I'm doing wrong as I think I'm following the steps correctly.
I've varied the time I hold the reset button after 10 flashes from instantly to a few second but it does not make a difference. I've also tried to ping 198.168.1.1 and always see the repose ttl=64, not ttl=100 as some other people suggest in other forums.
What ever I did with steps 7 to 12, it did factory reset the router. I have changed Rapps retrys back to 5 again.
- Netduma-FraserJun 20, 2021NetDuma PartnerJust to double check, did you enable TFTP for Windows as per the link at the bottom of the guide?
