sdog1010
Jan 24, 2023Guide
XR1000 dumaOS not loaded yet
Hi I have a XR1000 Router and when i try to log in with the 192.xxx.x.x it comes up with dumaOS not loaded yet. Can someone help? Firmware Version: V1.0.0.64_1.0.49
sdog1010
Jan 24, 2023Guide
add: the router is connected to a netgear CM1000v2 modem
- Netduma-LiamJan 25, 2023NetDuma Partner
Can you disconnect the power cable from the XR1000 for ten minutes, then reconnect it again and after a few minutes see if you're able to access the interface?
- sdog1010Jan 25, 2023Guide
explain to me like im a two year old what the R2 is đ
