sdog1010
Jan 24, 2023Guide
XR1000 dumaOS not loaded yet
Hi I have a XR1000 Router and when i try to log in with the 192.xxx.x.x it comes up with dumaOS not loaded yet. Can someone help? Firmware Version: V1.0.0.64_1.0.49
Jan 25, 2023Guru - Experienced User
Be sure to clear out all browser caches before entering the XR1000s web page.
Try a different browser. I use MS Edge here.
sdog1010
Jan 25, 2023Guide
ive tried that
- FURRYe38Jan 25, 2023Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? Don't load any saved config files from backup. Just new install using MS Edge browser?
- sdog1010Jan 25, 2023Guide
how do i do that, im not super in depth in terms of networking
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
Or press the reset button in back for 10 seconds then release.
