sdog1010
Jan 24, 2023Guide
XR1000 dumaOS not loaded yet
Hi I have a XR1000 Router and when i try to log in with the 192.xxx.x.x it comes up with dumaOS not loaded yet. Can someone help? Firmware Version: V1.0.0.64_1.0.49
sdog1010
Jan 25, 2023Guide
192.168.1.1
routerlogin.com
routerlogin.net
all of these lead to the dumaOS not yet loaded
Jan 25, 2023Guru - Experienced User
Press the reset button in back for 10 seconds then release.
Be sure to clear the browser cache before trying 192.168.1.1 after you release the reset button.
- sdog1010Jan 25, 2023Guide
ok... will try that tonight when i get home from class
- FURRYe38Jan 25, 2023Guru - Experienced User
I would disconnect the XR from the ISP modem before you reset it as well.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended. - sdog1010Jan 25, 2023Guide
as stated above im using netgear CM1000v2 modem instead of an ISP provided one
Ah got cha, early here. Off to get some hot tea.
Reset should get you going.
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
